I'm shocked....
I bet you are! LOL!
I'm shocked....
... when I connected the vacuum hose the pedal went to the floor aplying the bake. To solve that problem I attached a spring on the brake pedal to pull it back up. It work fine, but something tell's me that I shouldn't need that spring.
Does anybody know anything about this issue?
billgrissom - can you please elaborate on the location of the prop valve? why AFTER the distribution block? It seems that the rear brake line is just a pass-thru on the dist block? i.e. there is no distributing going on for the rear brakes at this location,, its looks like it just goes thru the block. The fronts look to be T split here 1 line in 2 lines out. But the back line looks like 1 line in, 1 line out.
I called ECI, and they anticipate that the rears are going to be doing next to nothing, and if i need a prop valve, its going to be to lessen the fronts to give the rears a chance...
i didnt expect that answer
they said try it how it is, and if needed squelch the fronts.
- - - im guessing that the prop valve is a cut-off pressure valve ? Like i hit 700 psi or lbs pressure or whatever and then i stay at 700 while the other side of the system continues to apply more pressure?
(the correct measurement is PSI . . . good ol interwebs . . .)
Sorry for the very late response. I just saw this. Perhaps someone else answered (didn't read all 12 pages). You are correct. You could mount the prop valve in the rear tubing, either upstream or downstream of the distribution block, since your car has separate F & R circuits (since ~1967). I was thinking of my 1965 car's distribution block, which is just a "quad T" with all ports connected. ECI's response is strange, and why you shouldn't take as gospel advice from whoever answers the phone. In a disk/drum car, you need to reduce pressure to the rear brakes, not the front like they say. If you don't, the rear drums will lock up the wheels much sooner than the fronts, which is very unsafe (rear slides around). Best to adjust the prop valve in a wet parking lot and keep skidding the tires and adjusting until the fronts lock up just before the rears.billgrissom - can you please elaborate on the location of the prop valve? why AFTER the distribution block? It seems that the rear brake line is just a pass-thru on the dist block? i.e. there is no distributing going on for the rear brakes at this location,, its looks like it just goes thru the block. The fronts look to be T split here 1 line in 2 lines out. But the back line looks like 1 line in, 1 line out.
i didnt expect that answer![]()
