Changing or shimming the pressure relief spring will only raise oil pressure IF the relief valve is currently relieving pressure at too low a setting. I was unable to find the designed relief pressure. think of this like a compressor trying to supply a heavy demand. If the compressor is not able to keep up, changing the setting of the safety valve will not increase the operating pressure. The pressure may be increased by reducing the load (i.e. reducing bearing clearances) or increasing the compressor size (i.e. high volume oil pump). Lindsay
