lemondana
I was going to post this on here awhile back but I got it on FBBO instead. Well anyway: I have a cheaper alternative to replacing this fan idler pulley. The repro's are pretty high. Most of the AC cars used these till 1972 I think. Check yours out-it might be rougher than you think, needing replacement. Continental which replaces Goodyear has a nice pulley. But you will have to remove the shoulder from your old one to use in the new one. As one member over on FBBO suggested, have the dust cover cut off by a machinist and you could probably use it on the new one-tack it in place. These are not common shoulder bolts, I have not been able to find them anywhere. The Continental number is 49034, they are only like 12.00 dollars on Rockauto. I have pictures if I can get them loaded on here.
