WANTED Front drum brake hub
D Cluley
Lansing MI
I've got a '65 Chrysler with front drums, and am looking for a hub. Left hand thread studs would be preferred, but not necessary. Will consider one with a good usable drum (11x3), especially if close enough I could pick up. Lower Michigan, NW Ohio, NE Indiana. I can only imagine what shipping will cost for a drum. ;)
The parts book just shows the hub/drum as an assembly, so different width brakes have different part numbers, but I think the hubs themselves are the same.
Thanxxx for the shoutout, TX Don't, however,
While I still have hundreds of N.O.S. Hubs & Drums
(1963 - 1964 Chrysler 11" x 3 " Keyway Rears // 1941 - 1954 Plymouth // 1936 - 1940 Caddy / LaSalle // 1941 - 1948 Oldsmobile & much more....)
I have sold all my 11" x 3" and 11" x 2 3/4" MOPAR Front Hub & Drum Assemblies
--- No one has manufactured them for fifty (50) years --- I had them *** NEW ***
N.O.S. *** up to about a decade or so ago....
Hubs --- are strictly in the --- U S E D world.....
Craig.....
P.S. I would not bet your bottom dollar that the 11" x 3" and 11" x 2 3/4" HUBS
are " the same "..... they may be a different height......
I have solved my immediate problem, but I may still be interested in a spare hub.
Didn't get the calipers out, but here are the basic dimensions of an 11x3 hub.
Diameter of the snout where it goes through the drum is 2.75"
Distance between the outer edges of the 2 bearing races is 3.25"
Total height of the hub is 4"
So I measured tonight with a cheap set of calipers. I will remeasure tomorrow to make sure my measurements are correct.
You will need to measure with calipers to determine if the measurements are the same or not.......
