Helo ladies an gentleman,
here comes my introduction and i'll introduce my Chrysler New Yorker:
Yeaaaa. I realize that the 1973 front isn't for everyone. Or the 4 doors. But for me it's just the right thing
! The car is an 100% Survivor. Nothing changed, except the radio.
So far I haven't found anything that's messed up or screwed up. Paint original, vinyl roof ok except for 2 small spots (nothing crunchy), trunk no water ingress/rust.
~76,500 MLS, credible but not verifiable.
I live in germany (Koblenz) and bought my NY in April 2023. It came from Athol, Idaho to Europe in Dec. 2021 and got his german historic car licence in 2022.
Breakdown of VIN #
CS43 Chrysler / Special / 4 Door Hardtop
T3C (Engine / Model year / Assembly Plant) 440 1-4BBL / 1973 / Jefferson, MI, USA
production codes
V1W (Roof, Vinyl Top Color) Full Vinyl Top; W = White
HB1 (color) "Blue Sky"
H7B8 Trim / Body Style
JB9 Upper door / Frameless doors
928 scheduled production date
124179 Vehicle Order #
E85 440cu in 4 barrel V8
D34 Automatic Transmission A-727 HD TorqueFlite
Sales Codes / Options
R32 Dual Rear Speakers (works)
G11 tinted glass
M45 Fender Skirt / rear wheel arches covered
P31 Power Operated Windows (works)
P41 Power Door Locks (working)
S61 Tilt telesc.str. wheel (works)
H51 air conditioning (without function)
R48 Power Antenna (working)
L31 Hood/Fender Mounted Turn Signals (works)
More equipment
Ventilated (heated) rear window (working)
Power steering and brakes (working)
Cruise control (works)
Hazard warning lights original from the factory (works)
Warning buzzer seat belt not worn (works)
Warning buzzer light on (works)
Warning buzzer key is in (works)
Trunk unlocking electr. in the glove compartment (works)
Converted to DIN radio in 1989 (replaced, didn't worked)
New aluminum cooler
Good tires, 8x15 rims.
Flaws (what I've seen so far):
Maintenance backlog, dirty as usual, cracks in the armrests on the driver's side, cracks in the steering wheel, the exhaust is a US homebrew job (done pretty bad), a lot of rust film. Heating disconected - new heater core is already in my stock ;). I found it due to recommend from this forum.
IMG 20230418 112025659 — Postimages]
View attachment 608986[/url]
IMG 20230418 122036800 — Postimages]
View attachment 608987[/url]
IMG 20230419 202550760 HDR — Postimages]
View attachment 608988[/url]
IMG 20230419 202614384 — Postimages]
View attachment 608989[/url]
IMG 20230419 204253168 — Postimages]
View attachment 608990[/url]
IMG 20230419 204308820 — Postimages]
View attachment 608991[/url]
IMG 20230419 222832466 — Postimages]
View attachment 608992[/url]
Matching Numbers!
IMG 20230508 155801332 — Postimages]
View attachment 608993[/url]
IMG 20230508 160418843 — Postimages]
View attachment 608994[/url]
IMG 20230508 160524340 — Postimages]
View attachment 608995[/url]
Pictures taken at the TÜV for an appraisal. Everything worked fine (except heating + air conditioning). He actually got a VIN engraved on the front of the frame, I hadn't even seen it before.
I'm amazed at how good it is after 50(!) years without a restoration
IMG 20230515 084011387 — Postimages]
View attachment 608996[/url]
IMG 20230515 090707337 HDR — Postimages]
View attachment 608997[/url]
IMG 20230515 090714249 HDR — Postimages]
View attachment 608998[/url]
IMG 20230515 090827802 HDR — Postimages]
View attachment 608999[/url]
IMG 20230515 090912428 — Postimages]
View attachment 609000[/url]
The Big Block ist spending WAY to much gas (at least
11,48 Gallons per 100 mls(US)) The ignition adjustment via the vacuum unit works again (replaced it).
Ignition is flashed warm with transmission in N and ignition timing deducted. Well in cold and only 5min time he was at +5 degrees instead of -10. That COULD explain the thirst.
Distributor twisted a bit... flashed off...-10+/-2.5 check. Immediately run more powerfully. But could only test 1km.
IMG 20230801 195333972 — Postimages]
View attachment 609001[/url]
Then he got a dashboard cover for a fortune, because the original dashboard is still great after 50 years and should stay that way. I think the carpet is cool
IMG 20230727 165649334 — Postimages]
View attachment 609002[/url]
But WONDERFUL how the Americans marked that!
IMG 20230728 201523611 — Postimages]
View attachment 609003[/url]
Very very cool: got a lot of tools for free today :cheers: ! Saved from scrap, a lot of Hazet and Made in Germany!
Soooooooooooo far. I'm glad to hear from you! I wrote a letter to the last owner in the US and I hope he gets in touch. Greetings Manuel
