jcloving
Stan,
Sugar Honey Iced Tea ought to do it. I recommend four or five servings.
Mine are at the machine shop as we speak. I figured since I have to send them out to be pressed in anyway, let them have the fun of getting them out. You're a better man than I am....
What do you think we're saving by doing it ourselves? At least a grand??
< Sent from my tablet >
Are all of them made in China? My future son in law works at Advanced and he says its hit or miss, some are American made and others are made in China. Are all your Moog parts made in China or some of them?
UNQUOTE.......those %$#@^%$ bushings were the worst I have ever seen to remove.
Yes full membership in 2004
I just got a call from the machine shop. They aren't ready as scheduled for this morning because;
QUOTE:
UNQUOTE.....
I just did this for my '69 Polara. Luckily I'm a mechanical engineering student at UC-Denver and the prototyping machine shop has a press; I did all the bushings myself although it took a solid 5 hours, most of that wrestling with the LCA bushings. One of them actually ended up not seating all the way down in the arm; I was using an aluminum cylinder to grab the lip on the end of the bushing to press on and once it got about 3/32" away from the bottom the cylinder just started yielding and cupped around the bushing. I kept at it and just ended up bending the lip on the bushing instead of pressing it in more... Hopefully with that added distance the torsion bar will still seat all the way in, of course I will be super pissed if it doesn't.
Lesson learned: If you cut/chisel out the old LCA bushing cups, make sure you go over the inside bore of the arm very carefully and deburr and clean it the best you can!
