commando1
I've set up my NYB to be that way. And don't forget the lugs for the Road Wheels are 11/16ths... :meh:
Leaky Tranny (caused by dried seals), leaky rad (caused by bent tube), never ending choke issues (Thermostatic control never works), then there's the never ending electrical nightmare. Oh, and the gas tank leaks too (reproduction sender doesn't fit the original tank properly.)That I understand. Are there different problems or the same one over and over.
That's why I bulletproof my cars. I go through everything and if it's a wear part and It's 35 years old I replace it. For example...new front wheel bearings, seals, rotors, pads, brake hoses, calipers, hardware, etc. So you get the idea. Same with the rear brakes, cooling (except the radiator) and belts, hoses, water pump, thermostat and housing. I also keep a tote in the trunk with the stuff that keep it from moving. Starter, fuel pump, ignition module, ballast resistor, voltage regulator, belts. I have no problem driving my cars coast to coast. I've been to Wisconsin and back 5 times already. What a blast it is on the open road with a big 4 door Formal!!!
I agree, 100% there's a toolbox in the trunk of the 73 with a few ICM's, Ballast resistors, a spare fuel filter, extra bulbs, fuses, relay's, the spare in the trunk is a good tire the same size as the ones on it, and I carry spare fluids (a must with my weepy old Plymouth)Nick, I just hate the thought of breaking down on the open road....especially because of an inexpensive part that most of the time you can't get if you walk in to most parts stores.
I'll certainly be at Carlisle this year with my 75 NYB. Although I've been to Carlisle many times, Never as a participant. When I purchase my ticket for On-Ground parking. How do secure a spot near the rest of you guys that are coming for the C body party? Or do we just go with whatever spot they assign me?Let's get back on topic,guys..
Pull through the gates and there will be someone that will give you directions toward your parking row. The class number is on your windshield sticker and have that in place (assuming you are preregistering). Look for a small sign directing you towards the parking row and then your row will be labeled. There won't be anyone parking you, so grab the last one in the row and back into there.
I'll be Pre-Registering yes.. So will we all be parking in the same area or will we be all spread out? I know we're not a Club so to speak, but with Carlisle giving the "C"'s there due mention, will they be parking all the "C" in the same area? I confuse myself sometimes.. :meh:
Nope, that's on the other side of the field. It might be worth an email or phone call to change class to keep you away from the neon colored Neons.I'm confused to. My dad signed me up for the "Young Guns" class, not C body. Does that mean I won't be able to park with you guys?
I think Ed is onto something with a large tent and featured "invitational" C bodies under it.
