Is a 70 service manual basically the same as a 69 service manual? Also looking for a good RH mirror and crate engine builder...
Australia
Hi - I am fortunate enough to have a copy of 1970 chrysler service manual, although I drive a 1969 newport convertible.
Is there likely to be any real difference between a 1969 newport convertible and a 1970 newport convertible? I would have thought there would have been very few changes as they are practically the same vehicle... I'm also after:
(i) a RH mirror, and
(ii) a reputable crate engine builder.
My 383 2 bbl goes just fine, with some leaks from the freeze plugs evident on the block. It doesn't leak much oil, even during 500 mile trips at 80 to 90 mph, sometimes 100 when overtaking road trains....I top up about 12 ounces every 500 miles. It doesn't leak any water either.
However, I have dreams of putting in a 440 when the the Inland Revenue Service finally stops hassling me... Your recommendation of a good create engine provider would be appreciated for future reference...
While you are right that differences between a 1969 and 1970 Chrysler are minimal and mainly pertain to exteror details, trim and upholstery, there were nevertheless some changes made to the inner works, too, especially concerning fuel and emissions-related parts.
Since you are from Australia, on which continent are you looking for an engine builder?
Thanks for your prompt reply.... Looking for an engine builder in the US... Even with freight, it will be a lot cheaper and likely more reliable than local Australian builders... With respect, local Australian builders will have less experience with big block chrysler engines - the largest engines that were put in local chryslers were small block North American 318s, 340s or 360s, and even they were quite rare.
...the main consideration for me is a builder who is reliable and has a good reputation for helping out you guys in the US...
Which State are you in? Plenty of local cars running 440s, a few with Hemi engines as well, both second generation and modern versions. Bergamin Brothers in SA are well known for their big power engine builds. Another option is Eagle Auto Parts in Melbourne: ChryslerMoparEngines.
I concur that '69 and '70 C-body cars can use the same factory service manual, for many things. As mentioned, the emissions items were calibrated a bit different between those two years, as was the pcv system in some cases. BUT, if one knows what they are looking at, these things can be worked-around, by observation.
Now, IF there might be any concerns, head over to www.mymopar.com and download a factory service manual at no cost. If you might not find "a Chrysler manual", then look at the same model year of C-body Dodge for a manual. Things like swapping radios and such would be different, but the mechanicals and electronics would be the same. NOTING that 1969 C-body cars had the ignition on the lh end of the instrument panel rather than the right hand side, as 1970s had the key cylinder in the steering column, as later models did. To me, "nuances" rather than major things.
69 and 70 have different ignitition switches and steering columns.
Thus the electrical will be different as well.
70 also has an electronic voltage regulator..69 was electro- mechanical.
As John says enough differences that warrant a proper shop manual.
There are differences in the steering column, ignition location and function, side marker lights instead of reflectors, and other minor areas. I would try to find the correct one, but that's me.
IMHO, there's enough changes from 1969 to 1970 that buying a FSM would be a good idea. For example, they made some changes to the charging system.
The cost for a thumb drive or CD of the FSM is really not that much. I've bought a few from this vendor. 1969 Chrysler CD Shop Manual 69 Imperial 300 New Yorker Newport Repair Service | eBay
Thanks mate - I'll invest in a shop manual. Have a great day...
There were differences in the engines as well. 70 lost a lot of compression across the board except the 426 Hemi. plus all the differences listed above.
Personally, I would put brass freeze plugs in your 383, and add a 72 or 73 intake and Thermoquad and be done with it! Unless your racing it, a four barrel 383 will give you lots of pleasure and better gas mileage than a 440!
In addition to the brass plugs, would you recommend a chrysler 360-400 low deck manifold with a 750 Holley?
I plan to go to Carlaisle this year, so maybe I could get a 72 - 73 intake and thermoquad there... I live in a very small town in the middle of nowhere (150 000 people that is 2 000 miles from a city - true, but hard to believe, I know) and they recommend a chrysler 360-400 low deck manifold with a 750 Holley....
This is why we really appreciate your North American advice and expertise...
For some reason I always think of a Holley as a race only carb. Some people love them, there's tons of parts for them, but I'm partial to Carter's. Maybe it was the whole power valve failure with one little backfire on the old Holleys. And they seem to leak fuel more. I'm sure the newer ones are better. Even the Edelbrock knock offs don't seem (to me anyway) to be as good as the old Carter's.
Now, I did purchase but haven't run yet, a Holley Street Demon 750 cfm with the plastic center because it reminds me of a Thermoquad. Has an electric choke which is nice once dialed in. I was going to put it on a 383 performer RPM because that intake isn't wide enough for the Thermoquad secondaries.
There isn't a good manifold made anymore for the 361, 383 and 400 to run a Thermoquad. Only thing out there is a stock factory iron or Edelbrock 2186 Performer which is just a light aluminum version of the factory iron.
I agree with your comment about the MPG, but not the Thermoquad. Barf!! Get an Edelbrock RPM intake and 650 cfm Eddy Carb from Summit.
Thermoquads can be tricky to dial in, but I learned from a guy who super tuned CHP carbs and had Chrysler engineers come out and document what he was doing, so I love the Thermoquad. And believe it or not, I gave input to Federal Mogal (Edelbrock carbs now) years ago about bringing back the AVS!
Experience with a big block Chrysler is magnitudes of importance less, than whether the machinist can make things round, straight, flat and square to each other.
My late machinist friend did everything front St. Lawrence single cylinder marine engines from the early 1900's to Rolls Royce Griffon V12's and everything in between.
The brand specific knowledge comes in more on max effort builds for racing. You need to know the engineering limitations of the particular architecture, cylinder heads flow curves, etc, so you can choose a cam that gets the last HP out of the combo.
Kevin
Thanks for that.... I'm in Darwin, but will reach out to Bergamin Brothers and Eagle Auto Parts too....
