Carmine
You raced a Viper for pink slips and won.
And your wife complained about having to drive the Viper homeYou raced a Viper for pink slips and won.
I suppose you know what happens when you leave a thread on a cliffhanger....You'll never guess what happened on the way home from it's first car show....
I'm guessing that rusty springs equals springs that have weak spots that are prone to fail.rust on the valve gear
When I lifted off he valve cover, oil poured out. The rear drain hole was fully blocked with gunk. I have to think those valves were oil starved and thus the break.Probably time to change all of the valve springs, also might want to check to see if you are getting adequate oil flow to the top end, photo shows what looks like some rust on the valve gear. Usually this means a lack of proper oiling.
I would just straighten it but that's me.
I'm going to replace this one and get the oil flowing and hold my breath. If a third one goes, I'll do them all. I have 3 extra springs sitting here.
Now, the pushrod. It has a slight bow in it. It's not not bent or kinked but bowed. Can it be reused or is it done?
Got the pushrod straightened out, but it won't seat in the hole. Sitting about two inches too high. I bumped the motor and nothing sounds funny. The motor drive home and shut down ok (running a tad rough though...). Inserting it is tough. The first two inches it goes in at a slight angle due to the brake booster but there is still lots of travel and free play. I can't imagine it is going down a different hole.
Ah! The same wood block I straightened it with! It has to be that...there is nothing else there.The lifter may be up in the galley, try tapping the push rod with a wood block to see if it will drop back down after you are sure it is seated in the lifter.
