Ah, yes, then the 1406 will be just fine. Are you going Pertronix on Mopar electronic Ignition kit?
Mopar electronic ignition.
I always used the Mopar kit as well. I have heard mixed reviews of Pertronix- some love them some have had problems. Just wondering which way he was going.
Pertronix would allow him to keep the firewall clean and "look" like it was all stock as if he managed to still be running LB.
Now...........
Are any/all of these needed?
Edelbrock/Chrysler Kickdown Extension Kit #8003/8004
Throttle Lever Kit #1481
Lever Adapter #1483pteL
LL
(Looks like it's needed to keep the Cruise Control?)
Edelbrock 8090 - Edelbrock Carburetor Fuel Inlet Fitting
(to adapt to stock fuel line?)
I think the eddy will bolt on (it has two bolt patterns). if you didn't buy the arm adapter/extension check your throttle pedal and carb wot I screwed this up on my bro in laws car cost me at least a 1/2 sec in 1/4 mile time if not more, I know your not going for that but just pointing out something to check. I think you would be better off ditching the lean burn, great idea but it is constantly retarding the timing for emissions, which is the reason for the multi-spark, all done without a feedback loop ( O2 sensor) I think this is why they are sluggish only feedback is vacuum.
I thought we just agreed the dual mounting pattern of the 1406 didn't need an adapter to install on the TQ manifold.Also need the 2696 adapter to bolt the Eddie to the TQ manifold...
Bob, I believe you, I know you are probably 100% correct and I won't dispute it.
But is sure LOOKS like the dual mounting pattern will bolt to a TQ manifold.
What am I not seeing then?
The dual pattern will bolt up no problem. The primary holes on the TQ manifold are way smaller than the primary butterflies on the Eddie carb. The carb throttle shaft won't open all the way without the 2696 adapter.
What happen? Did you do the conversion?Well....same old story.
1978 C-Body runs like crap with the TQ & Lean Burn.
The gas tank has been cleaned and new hoses at the tank, new fuel filter, and TQ cleaned. New plugs, wires, cap & rotor. Still runs like crap.
I'm going to try an Edelbrock 1406 and adapter plate on the stock manifold and see how it runs. I would like to save the Lean Burn on the Newport but it doesn't look promising....
