WANTED Left front wheel hub - 11x3 drum brakes
D Cluley
Lansing MI
The outer bearing race is not seating tightly, so I'm looking to replace a front hub on my '65 Chrysler 300. I would prefer a hub that is already separated from the brake drum as I assume shipping will be much cheaper but will certainly consider one with a drum that is in good shape. I would also prefer one with the left hand thread studs, but would not turn down a good deal on a right hand one (or even a pair)
Zip code is 48854
Thanks,
Dan Cluley
Zip code is 48854
Thanks,
Dan Cluley
Dan, if you're still looking for a hub, I have one from a 64 New Yorker, 11X3" drums. This is left hand drum, but I have both.
Good thing I never drove this car, no cotter pin in spindle. Lee
Not sure if '64 and '65 use the same hub. They made a lot of changes in '65 and it looks like they use different drums between the two years.
Would be best to verify part numbers before spending money on shipping.
Jeff
Jeff
I had the same thought, but based on the parts book, 63-65 all used the same hub & drum assembly. Learn something new everyday.
