rumpfox
you are way better off with buying a new set of hyperteck zero deck pistons or having the block bored .o20. you'll come out way better in the long run. i don't care what you do if you don't have comp' you're not going to make h.p. 8.2 is what is stock steel .020 gasket. a felpro is .042. a 72 or later cast crank eng. is only safe to bore .020 or you'll get cyl. dis.you have to think. a 10 .5 440 made an honest 375 hp. more than you'll need with 500 lbs. of tor. don't forget a cast crank req. a wieghted converter or, what i do is get on of those flex plates to take care of the bal. prob. that way you can buy a stall convert. another prob. with a super big cam. try to get a later mod. tranny. they have better internal improvements. yes you have to change the tranny also. big block trannies are getting real hard to come by over 30 yrs. since made.
