68plymouth383
I've been using a comp cam 260 high energy in my truck since 2003. I've also been using a comp cam 268 high energy in my 68 fury with a 440 since 2012. There great cams in my opinion.
Just to be clear. I did not make the original post. Nor do I know the person who did. I just thought that someone on this thread would have cam/piston rec from their experience, so I wouldn't have to start from ground zero.
My initial 1969 440 plan on a very tight budget:
As far as asking my question on page 8/9 of this thread, I regret not starting a new thread. The tone of this thread was too angry. Please remember: we're all on the same side. We all love c-bodies.
- Focus on torque more than HP because I really only need performance zero-80mph
- Clean block thoroughly and inspect carefully
- Retain original pistons and not bore, if possible
- Use a Comp Cams kit: XE256 might give regular gas a chance. XE262 would be better performance, but probably require premium. (I used to Mopar Muscle articles for guidance)
- Retain original iron heads. Have valve job done and rebuild with Comp's valve springs, retainers, and locks
- Edlebrock dual plane
- Holley 750
- DUI ignition
- HP manifolds, if I can get them and 2.5" exhaust
- 727 Stock torque converter, stock valve body with shift kit
- 3.23 8 3/4, Sure Grip
Iron is well known to make more measurable power - because heat=power and iron keeps that heat in the chamber rather than wicking it away faster. Coatings have come about for that very reason. Aluminum in and of itself does not make anything detonate less. It allows a builder to make other choices that provide value and benefit. In terms of racing - it's lighter which is worth a lot more than the few ponies iron might give. Any serious inquiry into having an iron block lightened to fit a class and you'll see what it's worth. Aluminum is also easier to port, and easilly repairable which also is a more important reason for a race application. So why use aluminum then? The chambers. Oldguy knows it but for some reason likes to keep the older iron around...lol. I like nostalgia but common sense usually wins out when I'm spec'ing parts for an engine. The aluminum heads all have a closed chamber (open chamber options aside). It's not a great closed chamber on most of the cheaper ones, but it is closed. Which allows me as the builder to take advantage of the properties of quench. Some may dispute those. The benfits are engineering fact but like all things some don't like change or think they know better. As this is my opinion anyway and unless I'm building for you, it doesn't affect me at all. My only request would be to show me any production car or truck gasoline powered engine that does not make use of it. So if you are repairing an engine - aluminum may not be the right choice as it's money with little more real performance benefit beyond what a good valve job might deliver. But if you have a clean slate - and there's not a rule that prohibits them I'd call it foolish not to use them.
In terms of dollars and cents - if you could run 87 octane fuel over the life of the engine vs 91 octane - would that $.40/gallon make sense? Over 20K miles (four years in most of the "summer driver" cars around me) that's $1866 in savings and you get port flow that matches a medium level of professional porting on iron. You also get a lot of weight off the front tires. So you're not spending fuel accelerating it.
Again - just my opinion.
Jeeze, Old guy. I understand the point you're trying to get across but here we're talking about guys doing a "rebuild", not building a race engine. And these rebuilds are for barges doing street duty.
Is there ANY practical common sense around here?
Now that makes sense. That's too much money.
The estimate was $675 & then another $200 for replacing the seats. He recommended changing them even if I got a set of 452 heads, as he has seen them (the seats) come off.
I plan on using the stock hp intake & air cleaner etc for a stock look. Alum heads with a cast intake just *feels* weird though. For the moment, I need a new harmonic balancer, if anyone has any suggestions.
