I read the Hot Rod article and found the quote below at the end:
"We're not going to be quite so cocky about debunking the claim that you can run higher compression on pump gas with aluminum than with iron. Our test does not definitively prove that. It may not have even tested it. We can say with complete confidence that we did not encounter detonation at any point during our testing, even at 10.88:1 compression. That could be because the cam was pretty big, with an intake-closing point 79 degrees ABDC. With cranking compression in the 185s, it was not taxing the detonation point even with 91 octane. Also, the Engine Masters thing has pretty well demonstrated that a dyno seems to have far more detonation tolerance than do actual driving conditions in a car. So, ultimately, we don't think we pushed that limit enough to make a positive finding."
1) They say verbatim that they did not resolve the question of aluminum preventing detonation better.
2) This is a test of a non-street Comp Cams 306S (PN 12-445-4), a mechanical-flat-tappet grind with 260/260 duration at 0.050 tappet lift, 0.555/0.55-inch lift with Comp Pro Magnum roller rockers, and a lobe displacement angle of 110 degrees. Who runs a .555 lift, mechanical lifter cam in a street motor?
3) They ran the engine on a dyno, not long term in a street situation.
I'm not the original post writer, but the original question was essentially: How do I build a 1975 440 street motor, never to be used at strip, with good power and reliability without breaking the bank?
I thought in reading 8 pages of arguing that we never really answered the original question. I say this because I need to build a street, internal balance crank, 1969 440 for my heavy, 3.23 geared 1970 Fury convertible, which I intend never to take to the strip. Inconclusive non-street dyno results don't help me much in choosing heads.
How about this: given that I keep my open chamber iron heads and do a basic port and polish with hardened exhaust valve seats, what cam and piston combination would you run? Please be specific by providing manufacturer, model number, and specifications. Please also state whether I can run regular gas or have to run premium gas.
