commando1
Dodge City is keeping quiet so let's move on to Chrysler. ☺
I went through all the 66-68 lit and it's consistent with adding VIP.
Last one from me on 1965 VIP. I do NOT think there was one Commando1..but we'll see if others weigh in with better evidence one way or another.
But, take a look hopefully without moving this thread in a different direction (somebody wants to bat it around maybe put it in another thread?) at a recently advertised car (NOTHING negative against the seller, NOTHING negative against the car is intended.).
Is this car a real 1965 VIP or was it "created" by someone in its past (without malice perhaps -- just didnt know any better)? See badging closeups at 42 seconds and at 2:23 in video.
"Up for sale in the .. is a gorgeous Mopar, the 1965 Plymouth Fury II VIP. The Plymouth Fury for sale is a model that was produced by Plymouth, which started from 1956 as a sub-series of the concurrent Plymouth Belvedere for 1956, then from 1957 to 1958, again, as a sub-series of the concurrent Plymouth Belvedere for 1957 to 1958, then became its own series, just one rung above the concurrent Plymouth Belvedere for 1959.... The word "fury" denotes a type of anger, inspired by the Furies, mythological creatures in Ancient Greek and Ancient Roman mythology. Above the Fury III, was the Fury VIP."
Am I mistaken, or is that not a 66?? Those look like 66 tail lights to me.
But the Monaco was just the top of the Dodge line.
The parameters have to be consistent throughout or a Sports Fury 3 will end up in there.
My vote is to add VIP for 66-79 using the Chevyboi criteria.
If you look at a car called Plymouth and it had only VIP emblems and you then refer to The Chart, it would not be a C-body. If someone saw a Dodge and it only had Moncao 500 emblems, by the Chart you would know it's a C-body because of the Monaco moniker.
That reasoning can also be applied to Monaco and Polara.Think of it this way...when that uni-body is first built, that specific body is not designated a separate line of cars. That particular body could wind up a Fury III. It only becomes a VIP once you add the trim level specific items and VIP badge to the car. A VIP is only a sub model of the Fury line; not a separate line of car. It's all about the badging, NOT the underlying body.
IF you call the VIP a different line, then you have to use Fury I, II, III and Sports Fury a different line.
The VIP is only a trim level based on the Fury line.
So if you want to use badging in your chart, then you'll have to go back and add the other sub models.
Don't make comparisons across different makes even under the same corporate umbrella. Plymouth did things differently than Dodge just like Chevy did things different than Pontiac. Each make of car had it's separate lines and trim levels due to where the make was positioned within the corporate structure and market.
I feel uncomfortable by disagreeing with you because of your dedication to documentation, but I think your opinion is biased because you get so heavily involved in the Price Class category working with VINS. I'm hearing the other side. I'm committed to getting it 0% wrong rather than 100% right.
...you can ugrade your Plymouth by moving up to a VIP from a Fury.
I want to add the Canadian models.The 880 went to 66...at least in Canada. My Dad had one.
