New project: Allen Engine analyzers, restoration?
For those interested in how these old exhaust analyzers work I will post a PDF of the service manual whereas the first section explains how the HC and CO levels are transmitted into electrical signals.
For those that were helping me, this is a different manual than what I was using, but seems to have more of the proper voltages (page 40 has the A101 circuit.) If you recall I was only getting 3.35V out of pin 6 of the A101 amplifier. In this document I should be getting 5V. To get the full picture I think I need to use both service manuals.
Below is the service manual that I have not been using that maybe I need to read. I may be able to boost the signal to A101 to get the 5 V, but still concerned about the "floating" signal at TP101.
  • 23-060, 070 Service Manual 25512.pdf
This is the manual I have been using. It has the overall larger schematics. Although the schematics for both look very much the same. Just one goes into further depth in other areas.
More reading to do this weekend when I get back
  • 23-060, 070 Service Manual updated 25565.pdf
It appears that the circuit has LM741 op amps. Maybe you can get a magnifying glass and look more carefully at the markings. LM741s are extremely common and inexpensive.
In this case A101 is labelled as RC15560N (see post 98) which is almost certainly a Raytheon part number, which I'm pretty sure would cross to a 1456 (ie LM1456) which is just a "hi performance" version of a 741. But that isin't the issue here, I'm sure that chip is fine. The input to this circuit comes from a polycrystalline lead selenide photo detector, which are sensitive to 1 um - 4 um wavelength (far infrared).
There's a small AC motor that drives a wheel with a window on the end of a tube contraption with a heater acting as the IR source, the light gets bounced down a pair of tubes, air pumps pull ambient air into one tube and tailpipe air into the second tube, the chopper wheel causes the IR beam to pass alternating through each tube, the photo detector will generate a signal that should resemble a square wave if the air in the tubes have a different concentration of I guess CO2 or HC. Without actually having either actual combustion gas flowing through one of the tubes, or a sample gas from a test cylinder source, you're not going to see a difference between the tubes. But if the wheel interupts the IR light then I guess you will see a signal. So this all depends of the contacts between the photo detector and the op-amp A101 is good, if the heater is working and generating IR light, if the detector is working and has a clean window, and all relavent reflector surfaces and optics are clean.
I am back working on this again. I made a quick YouTube video to better show what is going on. I am still at a loss why I am only getting 3 volts out of pin 6 on A101 when I should be at 6. Adjusting the pre amp is not changing the voltage.
The voltage on the op-amp output (pin 6) is somewhat irrelavent because it's being fed through a capacitor to the next stage so it is effectively at zero volts plus what-ever signal is appearing at the input (pin-3). Your test point TP101 is on the other side of this capacitor. What are you seeing on the scope on pin 3 when the input sensor apparatus is functioning (ie heater on, ac motor spinning) ? You should see an amplified version of that signal at TP101.
Pin 3 of A101 is 2.79V every thing running and warm. TP101 is jumping around but only around 100mv max.
On another note I am not seeing any voltage throughput on the photo detector (signal sync)on the sample side. Will get deeper on the next post.
Here are my readings at pin 3 and TP101
Pin3 A101
Pin TP101
More on the photo transistor on the reference side. Circut 302 This is probably reflecting my reading on TP101. If the photo transistor is not telling the A101 circuit that it should measure the reference side is that why I am may be getting an erratic signal? sample side is working (301) but am not getting power through the photo transistor on 302.
I am not sure what is first in the circuit but am not getting my 30V at TP302 (signal sync)
But maybe an additional issue.
Not 100% sure on my Photo transistor. Within Circut the resistance measures the same between the one that is allowing voltage to pass through (sample sync) and the one that has minimal voltage output. Not sure how to test. Could it be an alignment problem? I think the LED’s are working correctly as they are in series with one another and measuring voltage fine at the end of the circuit (P301)
Q301 is giving a voltage reading, but Q302 is not. I will try cleaning and alignment first. If that doesn’t work I will need to learn more about photo transistors and how to size them as original parts are not available. Not quit sure what TIL66 means, could it be the spec?
Thanks for the link. Mine is not quite like that style. Mine is soldered to two pins So not an in board style. Is it marked wrong in my schematics?
Top of board
I also found this.
Tested my phototransistors on the bench without the chopper wheel. Verified that the sample side is working, but the reference side is not. Also mated the known IR LED with the suspect photo transistor and validated that in fact the sensor was not working. Also did the opposite and validated that the IR signal from the led that supported the broken photo transistor worked to power the working one. So now at a stop with testing until I find a working replacement photo transistor. Here’s a video I did of the quick check.
Great troubleshooting work! I hope that you find the parts!
Well thanks to the site you linked yesterday I sent Inquiries on the Phototransistors and since and some capacitors. I figured if they have it and I would likely have a $10 minimum shipping charge, I would see If I could get all from one site. Fingers crossed. Thanks again for the link.
It seems the more I test and read the service manual, I am getting a better understanding of what needs to happen before it can work. At the beginning, I wasn't sure what controlled what and in which order, now it is seeming a little simpler. We will see if the Phototransistor fixes everything, or if I have to go on to the next item in the circuit. I have no idea if these machines were retired due to lack of service, or if they didn't work and it was cheaper and better to upgrade to something new. I really want to hook this up to my car and play with it this spring.
You are getting the understanding of its operation and that’s fantastic!
I am getting a way better understanding of this set up. Before the Infrared light can be read on the photo detector, the sync has to tell it which side should be read and then it converts the difference into voltage. Without the wheel "chopper" cutting the phototransistor off (little notch in the Chopper wheel) it doesn't know which side it is measuring. I didn't really understand that until I started checking how it worked and measured the voltage and re read both of my tech pages.
Your guys assistance has been great and I am learning a lot.
Thanks again.
What started as Voodoo, is starting to make a lot of sense. The Oscilloscope also really helped me better understand the circuits, as I could physically read and better follow what the schematic was telling me. I still need to brush up on how the 8 pin amplifiers actually work and what actually controls the voltage gain. I think I found some schematics for them, so will have to take a closer look. Knowing that stuff would be beneficial in troubleshooting.
Thanks again.
As I am waiting to find some Phototransitors for my exhaust analyzer (I have about 4 e-mails out for RFQ). Hopefully they respond to my tiny order) I decided to uncover my car and start going through my Allen15-110 engine analyzer.
Last time I could only get the oscilloscope to work. Now I am at least getting the volt meter to work and am getting the indicator lights on the other meters, but not gauge action. I know the tachometer is getting a signal as the ranging light goes on when I get above 1500RPM, but the low range light does not come on. Of course my schematic scan for the RPM circuit is only half there and blurred. I did clean all the boards yesterday and verified that I had +-15 and +-20 volts going to all and verified that I am getting input from the leads hooked to my car. I need to see what the RPM input voltage looks like next.
Here’s a quick video of what is working.
I exploded the needle for my amp gauge. When I was switching through the different tests. Still not completely working and now I will have to borrow the meter from my blue machine. Here is a video after I rebuilt my alternator. It now has the right pattern showing all diodes in the alternator working after I replaced them.
Pictures of alternator pattern before and after.
