Notes on engine and car after last night.
Car ran right up to 80 on the expressway with dead on tracking. Brakes even and straight. Very slight drift to right with slope of pavement.... normal.
Engine at speed was glass smooth and required only the least amount of throttle to maintain speed. Engine responsive, if a bit weak, at part throttle when at speed.
Full throttle from standing start results in bad bog which clears immediately if released to part throttle (just before opening of secondaries) no backfire and no popping.... and no stumble but a 1/4 second bit of a delay.... more of a feeling.... like a modern drive by wire. Not like the wagon where it is crisp and instantaneous.
Pulled over and leaned out the idle screws back to 3-1/2 turns out from closed. This had no effect on idle speed but resulted in slower rpm with tranny and A/C engaged.
Items to check:
Thinking timing, vacuum leak inside carb or past carb into manifold.
Install spare carb???
Set basic idle engine timing 10* BTC and rpm per FSM.
vacuum to cruise control.
Check fuel filter for debris. Change to transparent unit.
Check secondary choke plate operation... may be coming in too quick/spring not adjusted properly.
Spray carb cleaner to look for leak under manifold and at manifold/head.
More as I think about it.
Items to check:
