75LandYacht
Yank Tank
Well hello Javier.. long time no hear
![realcrazy :realcrazy: :realcrazy:](https://www.forcbodiesonly.com/mopar-forum/styles/default/xenforo/smilies/realcrazy.gif)
![Poke :poke: :poke:](https://www.forcbodiesonly.com/mopar-forum/styles/default/xenforo/smilies/poke.gif)
Speaking of upper and lower control arm bushings, where do you get your parts? I need to do mine as well.Corona virus house projects have kept me busy. Luckily, I can escape to the shop occasionally.
I took the car in for an alignment check. It was wearing the inner sides of the tread.
Needs new upper and lower control arm bushings. Ball joints are still good and look like they were replaced just prior to my stewardship. I had done the tie rod ends about 6 months prior.
So it should be good.
Going to rebuild the front brakes I think. Will start with a good bleed first. Right side is engaging harder and pulling. Worse after a bit of highway like the last time I saw Commando1. Last long trip
Here she is up on the rack.
Something to think about...Going to rebuild the front brakes
No... not yet but it doesn’t look too hard or bad. We set the alignment per the the FSM so it should be fine. Very precise machine.wow!!!! Do you know how to use it??? Let us know.B.B
I got my rotors from RA for cheap money expecting to have to return them.
They were beautiful American made () pieces.
The calipers which came -packed were perfect also.
Run her for a few weeks, she may settle a touch more. She's looking good, and now I don't feel so bad about how many weeks I hauled that dash pad aroundHere she sits now with the new front suspension and having take out the replacement front Windsheild out of the trunk..... finally.
Little proud at the front but even.
Thats one sexy car Javier.. That Silver / Burgundy combo just is perfect.Here she sits now with the new front suspension and having take out the replacement front Windsheild out of the trunk..... finally.
Lol! Every time I went over a bump, my ******* puckered as I remembered that I had a Windsheild in the trunk.Run her for a few weeks, she may settle a touch more. She's looking good, and now I don't feel so bad about how many weeks I hauled that dash pad around![]()
Javier I wanted to ask, I’ll be digging into my upper and lower Ball joints soon. Do need to take tension off the torsion bars at all? Or just put the car on jack stands and do it to it?Finished front end on Thursday. Today was brakes and calipers.
she rides like you’re in a cloud. All the little squeaks and groans are now gone too.
new front brake hoses
new calipers
front suspension showing inner wear on tires. Camber and toe in now holding as set. May replace the front tires sooner than later. They are relatively cheap.
Front brakes with new upper and lower ball joints. Said I wasn’t going to do it but I had it all apart and “what the hell”!
no more wandering and only the slightest drift to the right from the crown of the road. Just holding it picks up the drift. Very happy!!!!
