Also, be SURE your rotor isn't slipping! I had a slightly crooked cap on that caught the rotor, breaking the little tab that holds it in place on the shaft, and it made symptoms AMAZINGLY LIKE WHAT YOU'RE DESCRIBING!! After about 30 minutes of hair-pulling, I pulled the rotor, saw how it was broken, got another one out of my horde, got one of Ray's fresh clips on the distributor instead of the dangerous obscenity the former owner had rigged, and it started the first try! VROOM! I've had the rotor 180 degrees out of phase also. Mind you, I persist in using Kettering ignitions, but geometry is the same.
