Progress... 400/451 coming together
Cams finalized .505 lift 225@.050 108lsa should be a torque monster for sure to get the heavy car moving.
will do.... still waiting on the machinist to turn my counterweights down.... deck the block then balancing. The stall convertestartrs being built. decided to set the pistons at a zero deck and ill use a mls gasket so i can upgrade to a closed chamber alum head later on. Ill post pics when the machine works finalized and i can get things started for assembly.
Bought an intake off of ebay used m1 got a decent deal(somewhat) and I might have shot myself in the foot with this one well see. The rest of the parts are coming for balancing, sfi flex plate ect. and parts ill need to button it up freeze plugs ect. Then its setting piston deck height, enlarging some oil passages, getting the pick up drilled and tapped for 1/2" and hofully ill get the block home to start assembly :)
