Darter6
Hi James,I too owned a 79 at one point. This is just my 2 cents on the subject.
Mine was a 300 E58 with factory dual exhaust 4 bbl.
Car had about 80K miles.Had hard start problems at random. Left me stranded several times.As stated above I did the conversion from Lean Burn using the Summit kit.Removed the computer from the air filter housing.Cured my starting problems but no gain in performance.BUT doing that the factory Thermoquad does not have a port for the vacuum advance.I swapped to a 1973 Thermoquad.You can put a port into the carb you have. I believe there is a You Tube video on it.Or swap the carbs base plate.What did make a big difference in performance was changing out the exhaust system.My car had 3 cats and were plugged up.It would fall on it's face at wide open throttle.The system was bought from Tube Technologies Inc. TTI for short.I didn't make any internal engine changes.Sorry I ever sold that car. Just a few photos for you.You did say that you don't have to have emission inspection so you can free up the exhaust even if you went with single..
