luigi164
Any noise from the axle bearings? When they test drove it were the brakes smoking? If the bearings were causing the heat they should be making all kind of noise.
No, no weird sounds from the bearings...and if they were bad I would expect also some backlash in the axle ?
Everything heats up, axleflange, drums, the rim...but the hottest point was at the centre.
I'm also NOT convinced that the bearings are so bad and cause that much heat. Specially because the axle right behind the backingplate is not hot at all. I would think that would also be hot ?
I'm totally confused what's going on here. Talked with several people about this but with no solution yet. Next saturday I'm gonna take a look again with a friend of mine...
To be continued
