I have only seen the shoe arcing machine on line, I have never seen one at any of the dealers I worked at let alone the old service stations. Sound great, if you could get a hold of one.
I ordered newer shoes so they shouldn’t have asbestos… I hope. I couldn’t find anyone who arcs shoes near me unfortunately.Your mechanic needs help
The brake shoe springs are very worn out!!!!!!!!!! REPLACE
The emergency brake adjustment is critical Pay attention!
It's not the prop valve unless it's leaking
When the drums are cut the shoes have to be arced on a special fixture to match the radius of the drum. The lining material should be a modern material not asbestos.
Do not listen to the curmudgeons when it comes to lining materials
i think that that is beyond the range of possibilities. if he did find deflection, he should show you how he found it. unfortunately, i don't know that the stuck e-brake is causing an overheating condition so long as the shoes are able to seat on the stop and your not applying the e-brake after doing an assembly and proper adjustment of the service brake. without working on the vehicle, i don't have a good answer for you other than to say that any obvious defects should be repaired before looking for needles in a haystack. does makes me wonder how well the front brakes are working though. good luck with it and thanks for keeping us posted.I took the car over to the mechanic shop and he found a slight bend in the passenger rear axle shaft. That would probably be the cause of my problems.
He apparently used some sort of dial indicator as he spun the wheel. It was a slight bend but I guess it was enough to cause a slight drag on the drum. Parking brake is still on my to-do list. I will keep updating until I fix the issue. Thanks for all of the help so far.i think that that is beyond the range of possibilities. if he did find deflection, he should show you how he found it. unfortunately, i don't know that the stuck e-brake is causing an overheating condition so long as the shoes are able to seat on the stop and your not applying the e-brake after doing an assembly and proper adjustment of the service brake. without working on the vehicle, i don't have a good answer for you other than to say that any obvious defects should be repaired before looking for needles in a haystack. does makes me wonder how well the front brakes are working though. good luck with it and thanks for keeping us posted.
If he's measuring off the wheel, he's doing it wrong. That would indicate a bent wheel.. Did he say how much? If not, well... Find another mechanic.He apparently used some sort of dial indicator as he spun the wheel.
He measured off of the flange I believe. He didn’t give me numeric value… probably my fault for not asking. I thought the same thing. Bending an axle seems like a difficult task.If he's measuring off the wheel, he's doing it wrong. That would indicate a bent wheel.. Did he say how much? If not, well... Find another mechanic.
Honestly, bending an axle is kinda rare.
He should have told you the amount of run out without asking.He measured off of the flange I believe. He didn’t give me numeric value… probably my fault for not asking. I thought the same thing. Bending an axle seems like a difficult task.
and how does it relate to brakes overheating. on both sides. run, do not walk, to the nearest exit. given the competence displayed by the professionals working on this vehicle, i'd have cause to question all of the work mentioned in post #1.Honestly, bending an axle is kinda rare.
That’s what I was thinking too. There was never any major vibration that I felt. Kinda strange.He should have told you the amount of run out without asking.
If there was any amount that's large enough to cause this brake problem, you would have quite a bit of vibration in the rear while driving.
IMHO, this entire problem is hydraulic... But what do I know?
Maybe I should just give it a shot myself. But I’m honestly just a backyard mechanic, no real skill haha. I’m somewhat afraid I would screw something up. It’s a shame because I live on an island and it’s tough finding a decent shop. I brought my New Yorker over to a Firestone by me for an alignment and they destroyed my front driver wheel bearing… all the good ones are too far away hahaand how does it relate to brakes overheating. on both sides. run, do not walk, to the nearest exit. given the competence displayed by the professionals working on this vehicle, i'd have cause to question all of the work mentioned in post #1.
i would trust you more than the people who have worked on it so far. what you lack in experience, you make up for in caring. what makes rear brakes overheat? dragging or working too hard to stop the car. you have pictures of the drums removed. how difficult were they to get off? easy? they're not dragging 24/7. fronts don't overheat. that eliminates the booster or push rod. you changed the rear hose twice? replaced the distribution block. wheel cyls. good. no low brake pedal or brake pulsation. hydraulic issues are coming down to one last possibility... ask yourself some logical questions about the issue. you actually have more experience with your cars specific issues than anyone else, which makes you well suited to resolve it.Maybe I should just give it a shot myself. But I’m honestly just a backyard mechanic, no real skill haha.
I just reread your post and you say the temp gets to 300F. To be honest I don’t think this is too hot at all. It’s friction/heat that results in braking. Depending on the type of driving you do, how hard you brake and how often, the drums will get heated up. This is normal.Hello all. I have a '68 Newport with drum brakes all around. 2 3/4" up front and 2 1/2" in the rear. I had the brakes redone about a year ago. New master, wheel cylinders, hoses, shoes, hardware, wheel bearings, etc. I noticed that whenever I would take the car out for a drive, the rear drums got wayyy too hot (about 300 degrees F. on both). So, I figured maybe the problem was related to the proportioning valve, so I found an NOS P.V. on Hiltop Auto Parts and replaced the old one. Brakes still got hot in the rear. After that I thought it could be the drums and shoes, so I replaced them. Shoes are from Powerstop, and the drums are from Raybestos. Still very hot. The wheel bearings don't seem to be getting hot either. The major heat is coming from the shoes and the drums. I thought of everything and can't seem to figure out the problem. Not even my local mechanic can figure it out. Could the master cylinder be absorbing some engine heat and causing problems? Bent axle and/or flange? I have the car registered for the upcoming Chryslers at Carlisle event and I'd like to get this sorted out before going. I'm not an expert so any help on the matter would be greatly appreciated. Thank you!!
As a point of curiosity, what is your recommendation on a "modern material"? Brand? Type of lining material? Source (if allowed)? On what vehicle(s)?Your mechanic needs help
Right. So the last time I pulled the drum off was a couple of days ago after a short drive (10-15 miles). Rear drums were very warm. Passenger rear tire was smoking a bit and it reeked of brake material. Drum came off with no problems though. This was after I put the new parts on the rear and readjusted. I must have messed up my adjustments along the line. I want to get the car up in the air tomorrow or the next day and readjust all 4 wheels and see if that helps. I’ll keeps everyone posted.i would trust you more than the people who have worked on it so far. what you lack in experience, you make up for in caring. what makes rear brakes overheat? dragging or working too hard to stop the car. you have pictures of the drums removed. how difficult were they to get off? easy? they're not dragging 24/7. fronts don't overheat. that eliminates the booster or push rod. you changed the rear hose twice? replaced the distribution block. wheel cyls. good. no low brake pedal or brake pulsation. hydraulic issues are coming down to one last possibility... ask yourself some logical questions about the issue. you actually have more experience with your cars specific issues than anyone else, which makes you well suited to resolve it.
the part to watch is the circumference of the"hub" at the center of the flange. that's the part that centers the drum and wheel. that should be 100%. if it's not, at what point does it represent a problem. your only question is why the rear brakes run hot. i can't see how the first symptom of a bent axle is brake overheating.I can't describe the movement
i've noticed that but never thought anything of it. i've had cause to check similar things and always bolt everything together as they would be in normal operation. now that the shoes are worn in, the shoes shouldn't drag at all after adjustment. if you leave 'em loose, you might feel a little throw in the brake pedal before they apply, that's all.whenever I torque the drums down, it's as if the adjustment gets tighter.
coincidentally, that was the side where the e-brake lever was in the applied position. look at the pictures you posted. you should see the different positions of the e-brake levers. the spreader bar should not pushing against the primary (front) shoe at all. if it's not, then it's not causing a problem. thanks for the update.Passenger rear tire was smoking a bit and it reeked of brake material.
a friend had an E350 dually. was destroying the rear tires on the left side in a month. we checked the toe with a tape measure. one inch under on the front sides of the tires. axle housing was bent so bad it was naked eye visible. he had just spent a pile of money having the spring shackles replaced, supposedly to fix the problem. nobody thought to check the obvious.Now, IF you might check the toe-in of the rear wheels, there will be a slight amount back there.
