hauntedcbody
Leaving for a Colorado road trip on Wednesday...
As I've mentioned in a past post I have a couple broken bolts on the driver side head. One being on the valve cover. Attempted to just toss on a new cork gasket.. Which helped but it still leaked. So I yanked the valve cover again and replaced the cork with RTV to attempt to get me through the summer in hillbilly fashion. It actually worked for about a week or so then the leak got worse than it ever has been. So here I am yanking the heads at 12am on a Wednesday. I found one machine shop here in Cleveland that said they could probably get em done in a day. I'm thinking maybe if I grease the right persons palms I could get em done for sure by Monday.
So my question is.
At this stage (check out the pics) are there any tips or words of advice you guys have to speed up the process? Anything to avoid? Best place to find proper torque specs/pattern? Anyone know anyone with a set of heads laying around near Cleveland?
I currently have the passenger exhaust manifold off. Going to start on the alternator and the AC tomorrow then hopefully the driver exhaust manifold and finally the heads.
Summit parts List:
1.magnetic bowls....Somehow have never owned one of these
2.Plugs and wires
3.A new valve cover.. Dented up the old one due to prying on it to break the RTV
4.Head Gasket kit https://www.summitracing.com/oh/parts/fel-hs7891pt11/overview/make/chrysler/model/newport Is this a decent kit?
5.Head bolts
6.loctite
7.Wire Loom to clean up the wiring under the hood
Also the day I replaced the gasket with RTV I did a real quick clean up of the rats nest wiring and I think I may have pulled the blue wire in the picture off the alternator... After driving it I noticed the battery draining. There's multiple dead end wires under the hood so it kind of has me stumped.
So far I'm happy with the way the engine looks. Cam and lifters looks good. The Title and the odometer said roughly 60,000 so I think I can believe it.
Thanks for the knowledge everyone.. I'm slowly getting there. Learning more every project I do on this thing.
So my question is.
Summit parts List:
2.Plugs and wires
5.Head bolts
6.loctite
