Blocked off.
Has anyone tightened the bolts holding the carb to the manifold? It’s very easy to warp/crack the carb by over tightening those bolts. To check for this have someone sit in the car with his foot on the brakes. Then you spray foam cleaner at the base of the carb. Have assistant put car in gear while maintaining the brake. If it stays running you’ve found your problem.What would keep my 383 stalling trying to put it gear, it is warmed up enough. Just keeps stalling. Holley carb.
