max1196
Be sure to use a small amount of silicone on the front and rear ends of the valley tray, especially the four corners nearest the heads. Bottom side of tray of course. Do a trial run with the intake and the 3 bolts with the load spreader, aluminum intakes for some reason don't have the same clearance as the cast intakes, modifications to the chamfer of the load spreader may be necessary and overall height of the outer most spreader bolts may be needing a fix.
