@MoPar Maniac. thanks for the suggestions on Magnum Install. Wouldn't I have to buy a 1992 or 1993 and export all the dash and wiring as well as what you mentioned?
Coil: primary and secondary are within specs you gave, MSD coil 40000 miles
Grease: I've never heard of grease having a negative effect. I've used it for years to prevent corrosion and ease install. Of course, Accel ships electrical grease with spark plug wires.
@rags I have had to return 2 Echlin sensors. Echlin used to be a good brand. I installed Cardone new distributor (China). Bad pickup out of the box. Aftermarket quality is terrible. Thank you, China.
THE FIX
*pulled Cardone distributor. Tested sensor signal with feeler gauge. 6.45V V draw with or without feeler. Internal short. Without pickup connected, sensor voltage from computer is 5V, factory spec.
*Installed Mileage Plus Echlin MP827SB hall effect pickup in original distributor. Installed original Distributor.
*Took distributor connector and wiring from 92 van. Crimped to wires out of computer and bypassed wiring harness at firewall. Connect at distributor. 1990 W150 started for first time in 2 weeks.
Feeler gauge, remove and replace, signal voltage at grey wire should alt between 0 & 5 V if connected to car's wiring harness
Yes I used the one on the left. No side play in shaft. Cleaned it up best I could. Cardone pickup & New Echlin pickup also shorted in Cardone unit on right.
Oddly enough, the mounting fittings on Mileage Plus hit the shutters. Had to use the fittings from the shorted Echlin to mount Mileage Plus. Advance is also near by, but they have BWD, speaking of Chinese junk.
Zip tie wiring arrangement to see if it worked
It started. Since 7/28/20 I am on my 4th hall effect pickup, the 1st Echlin lasted a month, the 2nd Cardone and 3rd Echlin were bad out of the box. By comparison the hall effect pickup I had before 7/28 lasted from 2010 to 2020.
Next I have to return Echlin idle speed control motor. Will not adjust per factory specs, does not extend for fast idle after shut down, must start with foot on gas pedal. Date of purchase: 9/5/20
