I’m trying to find a suspension kit upgrade for my 1968 Newport. I would like to change the stance a little but not much. Any idea?
Turn that torsion adjuster bolt completely looseI am also doing a suspension rebuild on my 77 New Yorker currently, and how do I take the load off the suspension from the torsion bars so the steering knuckle does not come crashing down when I released the upper control arm?
Thanks,
77newyorker440
So, I have a 66 Newport and it just seems like the whole body sits a bit lower than it should. The leaf springs appear to have a reverse arc in them. Anybody have any suggestions here? As I recall from the 66 that I had as a kid, I just don't think it sat that low...
A flat spring to slight "reverse arch" is normal for these cars.
View attachment 460294Still look good to you?
I guess its just me then...just don't remember the one I had back in '81 riding that low. And given the way I beat the daylights out of that car I would think I would have been bottoming out all the time.Sure does. It looks to be sitting how my car does.
I saw a few picture of your springs in another thread. They don't look to be in need of replacement unless you need extra weight capacity or just have to have a few extra inches in height.
So, here is what I got from ESPO:It might not have. Different spring rates were available and air shocks were way too common back then. Also, that was 40 years ago. What did you have for breakfast 4 days ago? Besides that I guessing the driver is a little heavier by now.
To me it looks like it's riding right. On the low side, maybe, but still within spec. If for some reason it needs to come up or you just want it riding higher a new set of springs will do that.
