The paint job and putting a '61 fury back together
sb61fury
Rogersville, AL
Well fellow'61 fury owners my '61 got painted but the only thing that needs to be painted is the front fenders and the hood and the process of putting the car back together .It has been a good long journey on this car . Here are some photos I got to go in the garage after the garage was aired out of paint fumes and take some photos sorry about the quality of the photos
It doesn't look like the garage was quite aired out.....
Through the mist, it looks like a sweet '61 Fury though!
wet sanding and putting trimming on trunk Today I had to help my dad locate some of the trimming but the clips are in the glove box and the way to get in is blocked off with card board box blocking the drivers and passenger side to get in
The front fenders have been painted and neither have a hole for the antenna what do I need to do? My car did not come with a hifi radio .
that's funny, (kind of). I had to weld the antenna hole in my right front fender closed because I'm adding dual rear antennas.
I do have a 61 antenna with a NOS base bezel if you need one Steph.
Do you need a template for a antenna hole or are you going radio delete?
I need a hole for the antenna none of the front fenders has 1. I also have an FM converter so I can listen to FM but I would like to get 1 were I can plug my iPhone so I can listen to the music I downloaded . I can also do this get a am/fm/CD with a plug in so I can plug my phone in . I can also get a pair of surface mount speakers . I got some more photos
