live4theking
- Joined
- Nov 24, 2014
- Messages
- 12,897
- Reaction score
- 9,083
Pic's of this process????
do you have it painted yet??? By the way you stole the puller set for $42.50. I don't remember what my boss paid when he got the same set a few years back, but I know for sure it wasn't that cheap.I found the new set from Snap on, it has one other tool to hold the pulley, but you get the idea on the price. I am sure it would be higher if it came off the truck rather then ordering direct from Snap on
Kit, Puller/Installer, Air Conditioning
If your truck is charging you more, you have a greedy franchisee... in order to not damage the franchises, Snap On doesn't undercut them online or offer promotions through the website.I found the new set from Snap on, it has one other tool to hold the pulley, but you get the idea on the price. I am sure it would be higher if it came off the truck rather then ordering direct from Snap on
I suspect that is a MasterCool set... Snappy can't make everything they sell. IMO it is still top quality and a very good deal.Thanks for the info. Before I put in a bid on Snap-On puller, I checked all the similar Chinese kits on Amazon and elsewhere. They looked like a good deal, but the reviews indicated poor quality. Someone once told me: "Always buy the best. You will never be unhappy with it." I'm just really glad I got the Snap-On puller for about the same price as the el cheapos.
Great to see forward progress on the ‘vert. You have had so much fun these past few years with the parts car, will you be able to show the love to the ‘vert when she is up and running? How will you choose?
You want to use an oil pump primer. Remove the distributor and oil pump drive. Stick the primer into the oil pump hex hole and spin it counter clockwise (clockwise for a small block) with an electric drill until you have oil pressure. Giving the engine a couple cranks while doing this is a good idea.Guys: Sorry for the lack of updates regarding the Saga; I have made a lot of progress, and I'll post more pictures tonight. In the meantime, I am trying to get the engine in the convertible ready to start. I filled the crankcase yesterday, removed the old spark plugs (I used them to keep critters out of the cylinders) and hit the starter, so as to prime the oil pump. I cranked it a lot. . . But I couldn't get the oil pressure light to turn off, and the oil pressure gauge would not budge off of zero. I've worried about this all night. . . But I'm thinking this may not be a problem, because oil pressure high enough to turn off the light and register on the gauge, won't really be available until the engine fires for real. Can anybody comment on this?
What's worse. Effed up timing or running it with no oil?DON'T DO THIS! And now you've just F-ed up where your timing is! And now you have a hell of a time finding it again to get things where they were before you turned the key! Why? Think about it!
