I was waiting to see a pic of the bracket to see if i had one for you.
Gary:
I'm sorry, but I called Murray Park; he had one and has sent it to me.
Thanks again for the offer to help.
I hope you clean and paint the new one!!!!!!
Pic's of this process????Gary: Yesterday, I made an attempt to remove the existing 383 bracket from the A/C pump, so I could at least post a picture of the bracket. Should be easy. Huh? Nooo. . . The bracket is attached to the pump with long bolts that insert from the front of the pump from behind the clutch / hub assembly. To remove the clutch / hub, a C-3787 puller is required, which of course I don't have. Nothing that should be easy is easy. . . I shall continue to endeavor to persevere. . .
I just looked at the map to see where Germantown is, when we come down to see the wife's sister next time I may have to stop and see this ride in person. She lives in Annapolis
Dave told me the trick to remove it.To remove the clutch / hub, a C-3787 puller is required, which of course I don't have.
Think Sanden....Gary: Yesterday, I made an attempt to remove the existing 383 bracket from the A/C pump, so I could at least post a picture of the bracket. Should be easy. Huh? Nooo. . . The bracket is attached to the pump with long bolts that insert from the front of the pump from behind the clutch / hub assembly. To remove the clutch / hub, a C-3787 puller is required, which of course I don't have. Nothing that should be easy is easy. . . I shall continue to endeavor to persevere. . .
Think Sanden....
You should be able to rent a suitable tool from the parts store... or break your foot Dave's way...Gary: Yesterday, I made an attempt to remove the existing 383 bracket from the A/C pump, so I could at least post a picture of the bracket. Should be easy. Huh? Nooo. . . The bracket is attached to the pump with long bolts that insert from the front of the pump from behind the clutch / hub assembly. To remove the clutch / hub, a C-3787 puller is required, which of course I don't have. Nothing that should be easy is easy. . . I shall continue to endeavor to persevere. . .
Go with Stans suggestion, use your crotch.Move your foot.
He's laid up with a broken foot.5 days and no update...
Maybe he is icing his crotch.He's laid up with a broken foot.
