Vaanth
I modified these old screw drivers to be small pry bars for getting into tight spots:
HaI use this crude simple holding tool for holding the brake pedal down when I am bleeding the brakes using the pedal pump pressure method by myself. Pump up the pedal, then wedge the stick between the pedal bar and a seat track or bottom rail. It fits most of the cars I have. I've considered buying a good adjustable metal tool made for that, or just making a better tool, but this simple wood contraption always works for zero cost.
I have an old hole saw bit with teeth ground smooth to seat the caps. Good solid end to hit.A scrap 8-3/4" "489" differential crush sleeve makes a good driver for seating front hub grease caps into the hub recess.
It fits 3580894 caps on 1973 and later cars perfectly.
It also fits the earlier 1613416 caps, but with some play, so a little more care in centering is needed.
It doesn't fit the small caps used on 9" brakes, nor the larger caps used on trucks, etc.
Left=small, middle=3580894, right=large:
The refresh rate of the LEDs is out of sync with the refresh rate of the camera sensor (usually digital camera sensors have an exposure time of around 1/60th of a second, more than enough to pick this up), same reason why many car LED blinkers or even headlights in video playback appear to flash really quickly or at odd intervals.The "2" is lit, just not showing on this pic for some odd reason
I figured it was something like that. Thanks for the explanation!The refresh rate of the LEDs is out of sync with the refresh rate of the camera sensor (usually digital camera sensors have an exposure time of around 1/60th of a second, more than enough to pick this up), same reason why many car LED blinkers or even headlights in video playback appear to flash really quickly or at odd intervals.
