Tranny pan leakage
"Also, cheap Chinese aluminum pans are not ridgid enough to uniformly distribute the force from the bolt hole evenly. Give it a thorough cleaning, fill it with kibble, and use it as a dog dish."'
Thanks Commando. My cat will love his new food bowl. In your opinion, who makes a pan worthy? My wife is less than pleased with the transmission fluid stained cardboard under my Polara.
All joking aside, I would scour ebay and post a "Looking for..." in all the Mopar dedicated forums for a bone stock factory pan. I'd also weld in a drain plug.
I'm a HUGE advocate of stock items. Stuff like pans, thermostat housings, exhaust manifolds, etc...
They have never let me down. The factory pan is one super tough cookie.
I found this on eBay
Would this part work?
http://www.ebay.com/itm/200806364982?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
I don't enough about pan interchange to give you a reliable answer.
(Sent using Forum Runner)
I just called a friend about this. He said the truck pan is simply deeper to accommodate a larger valve body. It will fit and have about a 2 - 3 qt. larger capacity. He did say that he thought that price on ebay was way too high.
Your friend is correct. That pan is for a ''518'' which (in simple terms) is just a 727 with an overdrive. The aftermarket sells an adapter to lower the filter in the pan, if you want to go that route. I have used that pan many times without it (the adapter) with no problems.
Do you ever think about putting a 518 in a Formal?
Yes. Thought about it.
For the 25 miles a week I MAY put on it (if that much), I also thought why bother...
ROI would be around the year 2083.
I think about a ton of "what ifs".
Except for the thought of being locked up with a pair of drug crazed hot 18 year old twins, I dismiss most of them.
Not drug crazed twins....but will do in a pinch
images
images
Don't need to weld in a drain plug. I've been putting these in my 727 pans for years. You still end up with a bit of fluid in the pan...but nothing like the stock set-up.
I install it on the front right coner of the pan...about center of the curve on the body and pan.
The solution (for this pan anyway) is Summit P/N 93110 factory style silicone molded over steel 3/16" thick gasket. After warming up and topping up a retorque and voila no more leaks. Thanks to all the usual suspects for your valuable input.
Just to be sure once I install my factory pan I only need to use the previously mentioned gasket without any type of sealant?
My preference is no goo. Everyone has their own opinion on goo or no goo.
I used no goo. Torqued to 150 lbs after warm up . Rechecked after driving awhile.
