So we started to find out where the electrical issues were and began in the rear of the car. No reverse lights and we decided to check the bulbs. One of the lamps had no bulb and the other one wouldn't let go of the lens, so we decided to remove the whole lamp to find out more. Tight space and hard to get to, but we got it out in the end. Sprayed the bezel with WD40 and let it sit oversikt to see if it would come off, which it did. Two new 21w bulbs were installed.
We also found the switch on the shifter to be bad so a new one will be ordered monday morning.
Since it was so hard to get it out getting it back in wasn't any easier, so we loosened the rear bumper and pulled it back abit for more clearance. Behind the bumper there was a seal which didn't seem to fit very well and kinda lay on top of the licence plate light bulb. We pulled it off to see if we could fit it better, and what do you know - it was the seal I thought we were missing under the trunk lid, it was just put on there upside down..! All of a sudden we had that rubber seal in place after all, no missing parts there.
One never knows what to find when going thru these old cars.
In addition, the lack of low beams was due to two defect headlights, so new ones will be ordered too. I think we want to upgrade to newer halogen style lamps for future bulb replacements. I am also pondering getting amber lamps for the high beams...I like that old school look.
There is still a birds nest of wiring under the dash that will be looked into, but that will be adressed when we pull the interior and dash after the season.
