What 4bbl carb for 1968 318 fury?
xxcarguy
Claremore, Oklahoma
Hoping for some help. Would like to put a 4bbl carb on my 318. Bought a manifold.
Small bolt pattern compared to later carbs.
Pics for reference.
Would it be like a 65-66. 273 Hi po carb?
The current Edelbrock AFB and AVS2 carbs have the dual bolt pattern on the base plate.
A 600 Edelbrock bolted right on to my 273 manifold. Just make sure the butterflies clear the holes though. Depending on what carb, the secondary's may not clear. I had the machine shop machine the carb opening to clear. It's a common issue depending on what carb you use.
A 600 Edelbrock bolted right on to my 273 manifold. Just make sure the butterflies clear the holes though. I had the machine shop machine the carb opening to clear. It's a common issue depending on what carb you use.
Thanks great advise. Didn’t think of that.
Also, if you notice on your AVS in the photos, there is room to add holes for the narrower bolt pattern. Anyone with a milling machine could do that for you. But it might be easier to get a different carb.
Getting a manifold machined for carb bore/butterfly clearance will either be: a guy with a die grinder and carbide burr, or it's going to be expensive.
Machine shops are likely $100 minimum to do that unless they happen to have a fixture for that intake laying around.
Trans-Dapt used to sell an adapter to put the newer/larger Eddy onto an older AFB manifold. Don't know if they still make it.
If you get an OEM or aluminum intake it will likely be sized for 360 ports, and you should get one with smaller 318 ports.
Otherwise you'll have a bigger intake runner feeding into a smaller cyl head port. Guys do it all the time but it's not good for smooth airflow.
I don't know if an OEM 318-4 intake with small runners was ever made?
Aftermarket ones exist, but you'll need to scour for them.
I wouldn't fool around with spending $150 for a 60-year-old carb, who knows if the throttle shaft bushings will be good, rebuilding it, etc.
Buy a 500-600 Eddy AFB or AVS with electric choke, bolt it on and go driving.
Trying to hook an OEM divorced choke up to an Eddy carb isn't as easy as it seems it should be. BTDT. Hence why I recommended an elec choke.
Although you will need a 5-1/8" air cleaner to go the Eddy route.
To go teh 273-carb'd route, you'll need a 4-1/2" air cleaner, and that will either be an unsilenced unit from a 383HP, or a single/twin snorkel from a 383, or a 70s version from 360 or 400-2.
An interesting combination for Eddy carbs is to get an unsilenced Slant 6 air cleaner lid, and an aftermarket 10" chrome air cleaner with 5-1/8" neck, and use the base with the 6cyl lid. The 4-barrel unsilenced air cleaners (like in the picture) are getting scarce and pricey, the 6cyl versions not so much.
If you want to go this route, I have a couple of powdercoated 6cyl lids, I could sell you one.
If the Trans-Dapt adapter interests you, I might still have one of those left.
Carter never rated very many carburators for CFM. Attached is a link to try and determine CFM. Reality wise, figure a street (non race) engine will see 5500 rpm. The crude formula for a non race engine is 2x the cubic inches minus 100. That's about 530 CFM for a 318. The actual formula is cubic inch times max rpm divided by 3456. That comes out to 506 CFM for a 318. Hope this helps.
THE CARBURETOR SHOP / Aftermarket updraft carburetors
My 318 is a two bbl now.
What is the cfm on a 273.
273 carbs are just under 500 cfm. Forget formulas, an adjustable secondary like an AVS or TQ will also work. I've run a 340 Thermoquad 750 cfm on a 273 Commando and it worked perfectly. All you have to do is adjust the spring loaded secondary air valve.
