Stainless steel threads into aluminum easily. However, if one wishes for the two to play nicely over time, a little copper anti-seize compound is a must.
I even managed to find an upper radiator hose to fit.
What could go wrong now? Oh. Right.
The motor mounts were stock. 730 HP wasn't in their design criteria. So, I bought poly-locks from Schumacher.
I'd read that they don't fare well around header heat. So, I got some heavy copper foil and made heat shields. The right mount was used with the 1/4" shim from the last weekend. For some reason, it didn't want to exactly fit the chassis mount point. Remember, modifications rarely go as planned.
So, I broke another expensive cobalt drill bit. I'm almost to the point of determining that cobalt drill bits and hand held drill motors do not get along. I digress..
I clearanced the hole with a carbide burr so that the 1/2" grade 8 bolt, that came with the mounts, would fit into the vehicle frame. Then it would not start in the mount's nut. Out came the thread-restoring die and the grinder. I tapered the tip of the bolts. Here's something that is apparently exclusive to C-bodies:
It's a torque strap that was designed to limit the amount of pull that the left motor mount would be subjected to. I put it in place.
So, I managed to get the first couple of hours' work done in a full day. All-in-all, not a bad day. Tomorrow, I hope to finish the cushioned mounts for the radiator, put some cushioning under the Crane multi-spark box, start routing fuel lines and maybe even start some wiring.
Wish me luck!
- dad
