Xenon
This is why the people who in attendance should take *LOTS* of pics.....
I just watched a video of Tim driving it out of the garage, kick ***! By the way, that YouTube channel has some great videos![]()
Normally I agree with saforwardlook, but I gotta say...Keep the skirts...it's a New Yorker after all.
Well done.
The skirts also help with the aerodynamics.
They'll keep some air out of the huge rear quarters when drivin at high speeds.
I understand your points, because at least the fender skirts on a New Yorker are scalloped out some but then in time maybe get the springs in the rear re-arched or replaced to match the quality of the other work. I noticed that without the skirts in the first part of the video it looked better to me, less so in driving it in the garage with them on. It just looks too tail heavy to me leaving it the way it is.
But maybe that helps the burnouts create more smoke
I believe a car needs to have a proper stance to "pop" and I thought at least Polara 71 agreed with that philosophy in the past - maybe his preferences have changed with age.
One advantage C body Dodges in general have is a lighter/balanced look than the Chrysler models since they have greater rear wheel openings that improve the balance of the fuselage design overall.
If one likes low cars with short belt lines, then the Formal designs should be their destination. They look like they weigh 10,000 lbs and have boxy styling with prominent radiator ornamentation. That is when I jumped off the C body train. And probably at least one reason Elwood Engle jumped off the train in 1973. At least when he designed a formal looking vehicle, e.g. the 1961-63 Lincoln Continentals, they looked great. And their rear wheel openings were balanced to get that result. He rated up there with Virgil Exner in my book. I never liked the formals that were designed by someone else:
Great thread! Very inspiring.
(A set of Firm Feel tubular UCA’s would do wonders to the adjustability. You’d get both negative Camber, and lots of positive Caster, at the same time. I went that route once, and will do it again, eventually. Absolutely.)
