polara71
It is UNBELIEVABLE how level she stays .
I can't speak for the 71 but I would imagine you might have some issues. I know on my '66, when I eventually replace my single exhaust that it will need to be a custom dual exhaust installed.Question: does the FF rear sway bar work with TTI dual exhaust for a '71 C body?
Thanks
Thanks
I am fortunate to have an excellent shop.
I would think im the worst case you might have to have a section modified or possibly replaced but any good shop can do this. I think the rear sway bar is well worth it. One of the best improvements I made on my 300.
I have the rear out and springs ready to be rebuilt so i figure now is the time to consider a sway bar. Especially after the rave reviews. It is pricey, but then considering what I've already spent on the car, what the heckTTI or Firm Feel should be able to answer that. If the TTI system follows factory original bends on the pipes then , why wouldn't it? Mine is a 70 with original tail pipes , I didnt modify the exhaust.
Agree with above, it is a nice upgrade.
2 winters ago I upgraded my 66 polara 880.
With Firm Feel's full front and rear upgrades.
Also installed a 2.5 inch TTI exhaust at the same time.
I asked Firm Feel if their swaybar would clear the TTI exhaust. YES I was told.
I asked TTI if their tail pipes would clear the Firm Feel sway bar and was told that NO it would not.
So with these 2 different answers I mocked up the sway bar and ended up leaving it off because it looked to me that it interfere with the exhaust.
I am most interested to see how this thread plays out. I'd love to have the swaybar on the car
I haven't pulled the trigger yet on a new exhaust. Considered, TTI, Accurate and a third I'm forgetting the name right now. I thought TTI used all the factory bends. Accurate assures their buyers they are 100% factory.
I would think a " tweaking" would do the trick if there is interference. I wouldn't hesitate to do that if and when that happens.
For a 66 c body TTI dont use the original muffler hangers.
You need to bolt a mount on the upper shock mount bracket and things hang off the tailpipe. . Same as fuselage uses. I'm not sure if this changes anything regarding the pipe routing.
Accurate claims to be more exact to factory specs. I have their system for a 67 b body.
I havnt opened the box yet. I hope it fits up like it does on their video
