I have a 66' Fury 383/factory 4 speed. The previous owner replaced the clutch and a lot of other parts and in doing so it looks like he kind of rigged up some of the linkage to make it work. The over-center spring is missing and they just kind of added a second spring to the clutch fork and Z bar to pull the pedal back. I'd like to get it set up correctly and I am trying to find the correct parts to do the job. I'm trying to figure out if the Fury use the same linkage as the Charger, Belvedere, etc? All of the parts I've found say B body big block, so I wasn't sure if there was anything unique to the Fury as far as the clutch, linkage, Z bar, etc. I'm having a hell of a time finding anyone that knows much about 66 Fury 4 speeds!
