Valve Seals 10-2-18
#1 Exh, done. umbrella seal, rock hard
#1 Int, 2-groove keepers, old seal in pieces
Intake #1, new umbrella seal
Seal installed with dab of Sil-Glyde, also keepers
Intake #1, seal installed
#8 Exhaust, 3-groove keepers, broken seal
#8 Exh, installed
#8 Int, 2-groove stem
Firing Order, I did 1-8-4-3-6-5 today. #5
Right side
The valve seals I removed. Only 3 were intact and they are rock hard. Think we found the reason for my oil consumption. Unfortunately, there's probably a lot of pieces in the oil pan and/or pickup
A procedure for this tool
Valve Compressor Tool install, 9/16 socket, 6 ext, 3/8 R, 5 washers each rocker shaft bolt. Turn HB ¼ turn C, 1 ¼ socket, 3 ext, ½ R. Helper turned slightly more while I used straight piece coathanger to find TDC. Helper hold HB. Air hose tool install at SP hole. Air hose attach. Hammer and punch retainer to break loose from keepers. Tool: compress spring @ retainer. Keepers remove with telescoping magnet. Retainer & spring remove. Sil-Glyde seal & install, rock side to side to get past grooves for keepers. Sil-Glyde keepers. Helper still hold HB bolt. Install spring, retainer, keepers (right hand from outside, slide keepers around top of valve while holding retainer down with left hand on valve compressor tool. Release pressure on retainer.
