Left Side Grill Install
Extremely difficult because of incorrectly installed grill frame rivets and resulting warpage in NOS grill frame over time.
Flip Up Grill, initial position too low. S/B 3/4" from top of grill to chrome bumper
Warpage of upper grill frame
Flip Up Grill, Rear views, initial position
Tried adjust outer down stop upward with vise-grips. Heard small cracking sound and stopped immediately
Cut old rubber down stop pad and built up outer down stop to correct position. 3M Weatherstrip adhesive on rubber pads
Stationary grill, I had added 90° brackets 3/4" as lower mounting tabs
Tried everything to eliminate warpage in upper grill frame, manually pulling on each side of grill frame, redrilling upper inside mounting tab of grill frame. Nothing worked.
Finally pulled NOS grill frame off bumper, removed flip up grill, and examined NOS LS grill frame closely beside old broke tab LS grill frame.
NOS had 1/4" gap between to front of black vertical center support and upper inside grill frame. 2 pieces were flush on old grill frame. Black center support & upper inside mount visible in pic. (
@Factorial will be happy. 2009 Maytag Centennial makes another appearance.)
Drilled out 3 pop rivets holding vertical plastic of grill frame against metal vertical center support of grill frame. Pulled the plastic back against drill bit to slot the holes in the plastic. Installed 2 10x24 machine screws with nylon lock nuts and tightened while an assistant held the upper plastic tab against vertical metal support. Eliminated gap and reinstalled grill frame on bumper.
Added 1/4" bolt and nut between upper inside grill frame mounting tab and center of bumper to stop upward warpage in this area.
Stationary grill, final position. Installed with 6 x 32 machine screws, flat washer, and locknuts. Stationary would not align otherwise. Did not have a 2nd set of 4 metal clips.
Aligned view. Irony: a factory worker in Belvidere IL would have seen the problem with the grill frame and thrown it into the trash as a defect. Instead it sat on a shelf as a repair part for 30-40 years, waiting for someone to install it and correct the defects. In addition to correcting center support gap, had to drill new holes in both lower mounting tabs of grill frame and slot upper inside mounting tab. Job was time consuming, with much trial and error.
Final Result, LS Grill
