1970FuryConv
Some diff pics, 8 1/4, open, ratio unknown. topped gear oil with 80W-90
Still checking electrical issues.
Pulled the rear seat and left side quarter window panel, so I could check for a short in the intermediate wiring harness between the dash and the rear lighting wiring harness. Didn’t find anything wrong there, which is bad news because the shorts are upstream, under dash. Good news is that the floor under the real rear seat looks nice. Removing seat bottom is just push back to clear the 2 hooks and pull up.
Removing LS armrest and window crank helps give room to remove the top seat cushion
The top seat cushion has 2 mounting screws at the bottom and 3 hooks at the top. Once the mounting screws are removed, it’s lift up and take it out the door of the car
The Quarter window panel has a screw at the top front corner and a screw at the top rear corner and 2 clips at the front. Remove the 2 screws, pull the panel away from the support infrastructure so that the clips release, and you can remove the quarter window panel.
This rear door frame trim also has to come out
Superstructure
One last obstacle to removing the harness from behind its shield.
Remove the 2 screws holding the carpet to the superstructure, and then the wiring harness can be pulled out from behind its shield for examination. I was really hoping to find the shorts there, but no luck
Superstructure
