Hey Dave,
Is there any danger associated with the torsion bars with removing the steering linkage outlined here? Too, is removing the idler arm from the frame easier than just removing it from the center link (as suggested w/ the pitman arm)
thanks.
Torsion bars should be undisturbed, just don't nail them with any tools or the steering linkage. You do not want to ding or scratch the torsion bars. If you are paranoid about it, you can wrap the torsion bars with some shop rags or an old bath towel, even Several layers of news papers with some tape will work. As far as removing the idler arm either way will work. If the bolt thru the upper part of the idler comes out easily, that can be quicker, otherwise since you have the puller, removing the stud works fine too.
