Carriage bolts will NOT work.
The shackle bottoms out against the shoulder of the shackle bolt. This does two things. First it gives the correct clearance for the rubber bushings in the leaf springs. Second, it also makes the shackle stronger by being a solid rectangle. I've seen shackles collapse from not doing this right.
What I would do.... I really think the shorter shackle bolt is the same length as most other Mopar shackles. The leaf spring is the same width, so it stands to reason that the shackle bolt is the same length. I would buy a shackle (if you can buy one!) from Summit or ESPO and press the bolts out and into the old shackle.
Everything tells me this will work.
