I'm not sure which way I should go, I'm gonna call that guy about that 440/727 tomorrow, did you guys see the ad? I'm not sure about it though. It looks like the engine has been sitting outside for a while. I'm leaning more towards the shortblock I posted
Blueprint Engines BPC4080, Blueprint Engines Cast Iron Crankshaft Short Block Assemblies | Blueprint Engines anyone deal with this company before? They say the block is bored over .040 taking it from a 360 to a 400ish CID. That seem decent? The price isn't that bad I guess
I know $2k sounds cheap in a world of 10k project engines, but that is just the foundation. IDK anything about the quality of that company, but would be surprised if there was anything particularly bad about it... but now you need to buy all the other "stuff", cam, lifters, heads reworked or replaced... easy to get to the $10k mark from here.
Big block swap is viable, but I would start with a complete, cheap, rusty car. The RV engine is a good price only if its usable... other wise it's way over scrap value and I would wonder if the transmission is usable in a car. I think medium truck transmissions have different gear ratios... be surprised if it didn't, also might not have the right tail shaft for a car. Check for water and rust if you go there, pull the oil drain plug and walk away if water comes out.
Old carburetor engines are an easy swap, but when making a change I like the option of using anything I need from a complete carcass... the little stuff you find in a swap will often nickel and dime you at least another grand by the time your finished. If you have the space, keep the donor car throughout the swap, sell whats sellable to recoup whatever you can and the project goes smoother and cheaper. I bet you could find a good running rusty small block car for under a grand... probably not much different than a big block car, but no reworking the driveshaft, axle or exhaust.
If you go big block and find one of the Formal parts cars commando1 has been posting lately, I might be a player on some of the leftovers. But, I'm too cheap to count on as a way to pay for the entire project, so don't let that influence your decisions.
Tallhair got it right... Pull the donor first, running donor engines mean you know it will run once reinstalled, clean and paint the donor to your liking. Then on a long weekend pop out the old and work in the new... might get to test drive it Sunday if all goes well. In a fully equipped shop, I would count the swap as a day's work (long day, perhaps) and a few more to debug everything. A home setup and hand tools, a weekend is realistic... don't put yourself under the gun to finish in that time... lots of little things will be waiting to kick your *** doing this on old cars. I would get a squirt can and soak all the fasteners with ATF at least a day before work started... it makes life so much easier.
If you really want to go with a rebuild, consider the used swap first... then you can tear down and decide if the old engine is a viable candidate. If you go with the punched out short block, you will possibly have tuning issues if you do anything other than a stock build up... not a bad thing if you have the budget and really want the power, but a lot to spend if the small block doesn't fit your dream.
