saylor
if you go run it at 205 on the highway, then get to a stop, does it come back down to 190? every time? that may be your new operating range.
if it is 190 at idle at a stoplight, that's not so bad. if it can do that this july, that will be super even.
but on a traditional setup, usually it gets cooler not hotter when you get moving... unless something is wrong as mentioned above blockage poor flow etc.
that's a good lookin setup, it should cool your whole neighborhood. I vote lets try to get it working before ripping it out![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
as I understand thermostats, it is supposed to be fully open at the rated temperature. someone correct that is that is wrong.
a lower # will be fully open quicker. which may or may not be what you want. the coolant needs to stay in the tank long enough to get rid of some heat.
