Hipturd
Every cold start on my LA 318 2 bbl I get this residue out of tailpipes, anyone know what’s going on and remedy? Thanks
Actually my Fury is quite spoiled, she spends every night in a heated garageIt's because you're too far north, from the Great White North ;]
Wait a couple decades, it'll be like Mexico and you won't have the problem anymore.
The mufflers just got replaced so maybe I’ll try drilling a hole in each, if they don’t have anyWarm/hot exhaust hits cold steel exhaust pipe. Condensate occurs and usually collects in the muffler. Which is the reason for the small pin hole on the bottom of Chrysler mufflers, so the condensate can drip out. Condensate washes the inside of the pipes, which leaves the "trails" you illustrate. Completely normal, but a bit messy sometimes.
The other thing is that you should be DRIVING the car as it warms up, not letting it idle and warm up. In that orientation, the gasses get the pipes hotter quicker, possibly, so no "tracks" as illustrated. The side with the less track is the side with the heat riser. Heat riser closes and sends most of the exhaust to the opposite side, via the heat crossover in the cyl heads and intake manifold.
One of the flakiest things to watch is a late model Toyota as it is being driven around the sales lot, first start in the morning. Lots of condensate made, which collects in the muffler. A quick throttle input can result in a quart of so of clear water dump out of the end of the tail pipe.
DO ensure the choke is operating as designed. Might even clock the thermostat for the choke two notches leaner, for good measure. Then make sure that as things heat up, the choke will gradually open fully.
Is the mixture screw the one in front of the carb at the bottom and do you adjust it while running? I don’t know if it is the choke bc the soot only comes out immediately after start up.Normal during cold starts with choke still on with some unburnt gas.
As the engine warms up and the choke slowly opens up,the exhaust cools and condensation forms and thus leaving a carbon footprint.
If anything,make sure the choke and carburetor are set properly if you think it is too rich.
I don’t think it is burning oil , haven’t noticed any smoke during start up or while drivingToo rich, either choke or jetting, or burning oil.
yes it’s the water rinsing this out of the pipes when cold.
I agree with too rich, especially left side (driver side) of carburetor. Look at the difference between the black 2 carbon marks on the driveway.I don’t think it is burning oil , haven’t noticed any smoke during start up or while driving
If the exhaust heat valve is working correctly, most of the exhaust will be exiting the left side on cold start up.I agree with too rich, especially left side (driver side) of carburetor. Look at the difference between the black 2 carbon marks on the driveway.
Good point, thanks!If the exhaust heat valve is working correctly, most of the exhaust will be exiting the left side on cold start up.
valve seals? u know over time the rubber valve seals dry out & get hard . that it what it looks like to me . but then some motors do that the motor is cold & so r the pipes . ir called condensation my 72 new yorker does much like the something & its had less than 30k on the rebuild that i did it all myselfI don’t think it is burning oil , haven’t noticed any smoke during start up or while driving
My 65 with the 72 LA 318 engine is getting about 12 mpg on the highway at 55 mph, do you think should be getting better mileage?How many turns out early idle mixture screws?
If unknown, you can turn each screw clockwise until it seats, while counting the number of turns.
When I got my 1972 Fury, the left side idle mixture screw was like 2.5 turns and the right side was like 1.25 turns. I had a big carbon mark on my garage floor below the left side pipe.
For setting idle mixture, I usually put a vacuum gauge on the manifold vacuum port at the carburetor.
Then turn each idle mixture screw out from say .5 turns until I get Max vacuum.
Usually this is between 1.0 and 1.5 turns out from seated on both idle mixture screws.
Basically, you turn the idle mixture screws out until it reaches Max vacuum. Then you find that turning them out more doesn't increase vacuum. Then you go back to the amount of turns that initially gave you Max vacuum.
well i depends what gear is in it? the 72 318's was smogged out they cut the compression while a 70 318 in a dart with 3.23 gears would get 20 MPGs but it made more horse too (235 veris 190 in 72) IN A 3800-4000# B BODY THE 66 318 GOT 15 + MPGs it has to due with & hp. putting a smog 318 in the older car was ok but rebuilding the factory motor would had been better . & how many miles r on it iit its 50k i bet it needs valve seals & if its close to 90-100k then its timing chain time put a double row one in u will never have to replace it . if u dont when it throws the chain & it will then it will bend every valve in the motor costing u way more . how mechanical inclined r u ? can u tear the motor down & rebuild it?My 65 with the 72 LA 318 engine is getting about 12 mpg on the highway at 55 mph, do you think should be getting better mileage?
