What kind of issues? Just curious.
All an electronic ignition will do is fire the plugs more accurately than a distributor points set-up can, without any maintenance for a long time.
The one observed issue, from my experience, is that the cam lobes on the distributor will wear, with not all of the peaks being the same height. That will affect point gap AND dwell, which fires the plugs. I came to realize this when I was trying to get the dual points set correctly on a Chrysler factory dual point distributor. That's when I got the old Direct Connection distributor kit and never looked back.
One OTHER observation is that, at that time in the 1980s, very few if any new point sets came with the little vial of "rubbing block grease", which IS necessary to get the normal 12K+ miles out of a quality point set. As soon as the rubbing block wears, there goes the point gap and dwell settings!
Something which tends to vanish with an electronic system is distributor shaft/bushing wear. With no side forces from the point set spring pushing the distributor shaft to the side, wear is greatly reduced.
AND . . . you'll also need an electronic (transistorized) voltage regulator (if you don't already have one). You'll also need a strong and reliable battery (if you don't have one already) as the electronic box will need a certain amount of voltage supplied to it to fire the plugs.
Have you checked continuity of the power feed to the ignition switch THROUGH bulkhead connector? Resistance, too?
Take care,
