FI pump in tank
Will you be using a different sending unit?
I'M going to use one of the tanks inc floatless sending units thats set up in with the electrical resistance (ohms) range for mopar
I did get B-body EFI tank installed on 72 Fury. the filler neck is not able to bolt up as it sits but is installed. I will look at that in a couple more days, right now cleaning up the final wiring. Car starts right up and got most of the factory gauges working. Once I test the cruise control will try the late 80's speed sensor with mechanical speedometer cable.
