live4theking
- Joined
- Nov 24, 2014
- Messages
- 12,766
- Reaction score
- 8,976
Glad you got it.
Thanks John. You always seem to know the answer! I did see a compressor but it would of never crossed my mind.
Someday I’d love to do a restoration. Nothing concurs. The bondo is for sure going to be looked at. Sooner rather than later. Hopefully they killed the rust before putting more over it. As it is now - I’d like to drive it as much as I can and enjoy it!
first of all congratulations.
I think that there is a bunch of rust in the quarters unfortunately.
They lower part of the quarters would be an easy fix but the wheellips are rusted, too. Difficult to repair if you don't have a clean wheellip out of another car as there is no excellent repair sheetmetal available.
Carsten
Welcome to the 1970 Fury III convertible club. Looks better than Emmett's car in Richmond, plus more rare and convertible. Congrats!
Im sure it will be an expensiver fix. I'd like to do a majority of the work and prep myself when it gets to that point. Is the wheellip section able to be cut from other fuselage c-bodies? Or are the dimensions strictly to the Fury?
I’m glad I ended up going out to see this one. This one actually has a trunk!
Wow, sorry to hear about that, but glad you are ok and didn't lose a whole lot on your ride. I hope things get better as you continue to check things over on it. Good luck. DaleSo I guess misfortune tends to favor the fortunate in many ways. I took the car out to go give it a wash as I still hadn’t been able to give it a proper cleaning since I bought it and it was still filthy inside. Very shortly after I took off driving, I can smell a strong sense of paint enamel. Like as if someone was spraying aerosol cans at me. Coincidentally I was driving directly through a construction site, so I chalked it up to outside air as my foot vents were both open. The smell goes away for a little and it goes away from my mind.
I decide to park, and put the convertible top down since it was a sunny bright day out. I then start driving. Immediately within 30 seconds, the cabin starts filling with the strong sense of the paint smell. I immediately think “is this air coming from my engine bay?” I close the vents and I could still smell it. Immediately after the smell becomes unbearable, burning to the lungs and smoke engulfed around me. I quickly pullover to the side of the road into an empty parking lot and try to locate the source of the smoke. It’s coming from under the rear seat. I immediately think it’s the convertible top motor burning up or the wiring leading to the rear tail light cluster. As I had just put the top down.
I run to the front, pop the hood and cut the negative battery cable. I then pop the trunk to see if it’s the rear cluster. It’s not and the trunk is seemingly empty with smoke. I wait for a second to see if it dissipates but instead it intensifies. I immediately call 911 and luckily - I was literally within 500 yards of a fire station precinct.
Mind you - normally I keep an extinguisher in my New Yorker but I had not had enough time to buy one for this car as I just got it 3 days ago. Thankfully I had just added the fury to my insurance policy, effective last night so had it been unfortunately worse, they are some peace of mind.
The fire department and units come and are forced to pry the seat out of the mounts. As soon as the seat hits the open air it sets ablaze. Thankfully they put it out but not without alittle damage to the seat.
The cool the car down and upon our inspection - it was no wires or electrical. Seeing that the muffler is directly under the seat, Their idea is that the muffler gave off enough heat to transfer through the floorboard, then melt the bubble wrap padding, burn the carpeting and starting burning away at the seat fibers.
I checked under the exhaust and there are no obvious or glaring cracks, holes, dents or bulges in the muffler or exhaust system. I inspected the welds around the pipping and they look professional.
I’m upset about the incident but like I told the responders - I’d rather lose a seat then the whole car. One of them told me that “Hey - at least we helped you take the first step to restoring the car”. Not a single wire was burned and upon turning the car on again - there isn’t much heat transferring - at least in the small amount of time I checked.
I checked both rear floor boards and the left is very thick. The passenger side rear is noticeably weaker and thinner, and has some give but no holes. That obviously will need to be patched.
I’m not sure even if I had an extinguisher or gallon of water if I could’ve done anything better to save it. Unless I had a long pry bar and was willing to tear the seat out expeditiously - which knowing me I wouldn’t have the heart to do.
My first question is - did these old cars come with heat shields that dissipate heat?
Secondly - tips for the future. What should I be looking for that I may have missed? What can I do better next time?
Wait, just looked at the muffler pic again, has it been hit and pushed up against the floor?
Yeah there should be at about a minimum of 3/4in gap between muffler and floor.Inspecting more around the rear of the car - even the seatback has more bubble wrap an extreme amount of padding. Even the right side panels are filled with bubble wrap. Poor mans sound deadener? There wasn’t any on the passenger side - I wonder why.
Pulling out the seat back I suprisgingly found the build sheet. I was confident whoever did the half assed back insulation would have trashed the sheet.
And Ta-daaa.
Lots and lots of acorns. Somehow none of the wires are chewed through and the seat isn’t eaten through. I suppose whoever made this their house had enough respect not to trash the place...
The muffler has an awkward cant and tilt. Not normal. I can’t feel any holes. It feels like the muffler is physically making contact with the floor. Enough that I can’t even slide my phone in between the gap.
I think you’ve got these the smoking gun.
